1984 Sprocket options?
Hey guys, A 1983 Honda 200? chain drive called me today, and ask me to bring her home, so I did.
Q. Can I change the front drive sprocket to 420 pitch chain to match a gokart project I have?
also are there other tooth count sprockets available for this engine?
There may be a chance I can reuse the Honda sprocket on my gocart axle, I have gotten that far yet. Just looking at all my options.
Anyone need any 200? parts?
Thanks
MrC.
Weren't all honda atvs and trikes all 420?
I looked up a replacement chain and it is listed as 520,
Thanks
MrC.
Ya the 200s, 200x, 250r, 350x are all 520 chain. I know the 200x is a 20mm sprocket shaft, not sure about the 83 200 you have, you’ll need to do some measuring. I think I’d invest the $12 dollars on this one to see if it’ll fit yours, I’m willing to bet it’s pretty close. Your only issue maybe the teeth on the shaft, there either 4-5mm side teeth on the shaft.
This 420 (pic) maybe worth trying.
Good luck,
Shep
Assuming that this is a 1983 model, it appears to be an ATC200E, not an ATC200. It has electric start and appears to have the hi/lo behind the recoil starter. It may or may not make a difference on ordering sprockets.
//ArrowChat Integreation Code
