Results 1 to 2 of 2
Thread: Adjustable cam gear
    Nov 2015
    Davenport iowa
    1,144
    Adjustable cam gear
    Has anyone ever had any experience with an adjustable cam gear for a 90/110 and the purpose behind them? We have a gear with mounting holes all the way around it but are at a loss as to how you dial it in. Another thing is a condenser testing can this be done with a multi tester? Can’t figure out the whole charging and spark thing.
    1974 original 90 X 2
    1974 Original 70.
    6,803
    An adjustable cam sprocket is basically that , for fine tuning . A degree wheel is usually used .
    Capacitor works kinda like a battery , holds a charge and amplifies the spark . A bad one will usually show leakage but I’m sure the manual will show the method for testing it’s condition .
