Thread: can you interchange crankshafts between years?
    Mar 2018
    Halifax, NS
    34
    Hi, I have a 1982 atc70 and the crankshaft is quite damaged (keyway is a mess and the thread is damaged.
    I can find one for 1978-1980 but none for the 1981 and up... does anyone know if there is much difference?
    here are the part numbers:
    78-80: 13000-098-761
    81-up: 13000125000
    thanks for any help! The atc70's timing can't be adjusted other than from the plug gap. This one has a worn flywheel taper and worn crankshaft so I will need both...
    Thanks
    David
    6,811
    Cranks are different , different flywheels . Spark is advanced threw the points gap , set them at .014-.016 .
    Mar 2018
    Halifax, NS
    34
    Hi, yep I did that adjustment but as the keyway was wrecked on my crankshaft, the flywheel clocking may be slightly off affecting the clocking of the cam that opens the points.
    Cheers
    David
    Mar 2018
    Halifax, NS
    34
    alright. I just found a nice looking crankshaft and flywheel on eBay... the teardown begins tonight
    Thanks!
