Results 1 to 7 of 7
Thread: Did I screw this up?
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    Rebuilding my '84 200M. Started fitting the rings onto the Piston. They all seemed to go on fine, just working by hand very carefully. But I'm concerned I may have stretched the 2nd compression ring slightly? Seems like it fits really big on the piston. It's the right thing for the Piston, I know that much. I would have thought it would crack before it would stretch no?
    Here's a few pics....any tips are appreciated.
ID:	261305Click image for larger version.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    6,798
    Typical with aftermarket rings , I’m sure it’s fine .
    As long as it's still flat you're probably okay.
    I work them on slowly and one side at a time thru the grooves because they do break easily!
    Jun 2015
    Oklahoma
    732
    It's a Shindy piston with TPR rings btw. And yes I worked it on carefully, I know they break easy so I was very careful. But you still have to stretch it a bit to get it over the piston. I worked it down a little at a time. It looks like it's flat still. It compresses and goes into the cylinder fine.
    Da velder
    Feedback:
    Jul 2018
    TN
    1,065
    Don't matter how many you build, your azz draws up every time you install rings. LOL! I'm sure it'll be okay.
    Jun 2015
    Oklahoma
    732
    Welp it's together now! Thanks guysClick image for larger version.
    Da velder
    Feedback:
    Apr 2014
    Edmond, KS
    2,591
    The rings are supposed to ride fairly tightly against the cylinder wall so that will hold the rings in place.
