Results 1 to 11 of 11
Thread: Honda atc model identification
    Jan 2020
    Saskatchewan, Canada
    3
    Hey everyone, im new here and just bought my second trike today. Unfortunatly im having some trouble figuring out what it is. I bought under the assumption its a 1981 atc 185. But there are no stickers on the body saying what it is. The vin plate says its an 1981 but the 1981 185's didnt have 25 inch tires which is what i have. Any help is appreciated.
    Feb 2013
    Ontario
    812
    This might help
    But there is also a link to enter your vin to tell you the exact year and model.
    COUNT FROM LEFT TO RIGHT 10 CHARACTERS. Compare the 10th character of your VIN with the chart below.
    THIS IS FOR MOST BUT NOT ALL BIKES
    1980 = A 1981 = B 1982 = C 1983 = D 1984 = E 1985 = F
    1986 = G 1987 = H 1988 = J 1989 = K 1990 = L 1991 = M
    1992 = N 1993 = P 1994 = R 1995 = S 1996 = T 1997 = V
    1998 = W 1999 = X 2000 = Y 2001 = 1 2002 = 2 2003 = 3
    2004 = 4 2005 = 5 2006 = 6 2007 = 7 2008 = 8 2009 = 9
    Jan 2020
    3
    Thanks for that but i was looking for if its a 185 or 200.
    May 2013
    Brownsville, Tn.
    1,271
    Sounds like a 200. Check the numbers on the motor or look at the CC's on the side of the cylinder.
    * Nicholson 500 Race Bike *
    Jan 2020
    3
    Well i checked the engine numbers this morning and it came up as a 200. This is good new because i actually have 200 instead of a 185. Thanks for the help.
    Apr 2012
    USA
    4,129
    Use this page to get the year + make of the frame (VIN number), and the year + make of the engine (engine serial number). The cylinder could also be swapped from one engine to the other with the matching piston and such. Doesn't make much of a difference though, year to year the 185 and 200 matched up more or less perfectly parts wise unless you go to other models like the 200m, e, es, x, etc.
    https://atvmanual.com/honda/interact...er-atv-and-atc
    May 2023
    Wills Point
    TB01E-3001163 what yr is this
    Apr 2012
    USA
    4,129
    Nov 2023
    Yuma, Arizona
    Tb01-2009379
    Hello. Link doesn't seem to be working for me, bit I am most likely goofing something up. Hoping to get model and year imfo from this frame stamp ftom a small Honda three-wheeler.
    TB01-2009379. Much appreciated. Thank you.
    Nov 2023
    Yuma, Arizona
    Tb01-2009379
    Apr 2012
    USA
    4,129
    Looks to be working fine for me, make sure you have javascript enabled, most browsers have it on by default but some privacy focused ones do disable it. There's also plugins for disabling it as well which would break the page.
