Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
Thread: What do you call these?
  1. #31
    Aug 2016
    East of Worcester ma
    1,370
    Learned something new today, don’t use metal washers as part of a mold to help make a tighter fit on something......
    Won’t just slide off (rubber too tough) and need to cut the washer off which can’t happen.
    Now gotta find those plastic washers i have somewhere...
    Atleast half the mold is still good.....what the heck was I thinking...
    Shep
  2. #32
    Aug 2016
    1,370
    Ok- done. Nice tight (er) fit. Now I’ve got a question for you, the opening (top) it’s like a 1/4 inch opening I believe for just 3-wires? Want me to close that up a bit? Or leave as is
    I could make that end solid 1/8 thick rubber like cap that u could just make holes for the wires (water tight) if that makes sense?
    Shep
  3. #33
    Mexico
    9,018
    Standby.....
  4. #34
    Aug 2016
    1,370
    I Wasn’t thinking that you’ve got, or that there’s a sleeve that goes in there too. Probably best bet is to leave it like it is. (The opening) top
    I think.
    Shep
    And smudge some silicone around the sleeve if need be/ there probably was some from the factory, maybe.
    Easy to close it up a bit though
  5. #35
    Apr 2012
    USA
    4,133
    I suspect the harness tubing went inside of the boot, and harness taped around it to "seal" it and hold the tubing in. Could be wrong though, not a type I've worked with much.
  6. #36
    Order a nylon washer assortment from somewhere, I've got allot of odd balls but an assortment would be the balls...
  7. #37
    Mexico
    9,018
    Seems I just lucked out and got an OEM part in good condition off of eBay. As you can see in the photo it’s a loose fit right from the factory. The SHEATH on the wiring which contains four strands is .300 inch in diameter. If you can reduce the sleeve ID slightly it would be a much better fit.
  8. #38
    Aug 2016
    1,370
    Ok sounds good,
    What I’ll do is send you 5 of the exact (top size) opening copies there just under 5/16”
    -I made a few-
    Now (tonight) I’ll slim down the (top size) opening and send 5 of those too.
    U can pic the one that works better and have lots of extras
    I should be able to ship em’ out on Friday
    Same return address correct?
    Shep
  9. #39
    Mexico
    9,018
    Ok sounds good,
    -I made a few-
    Shep
    I tossed a paper with the shipping address in the box.
    Please PM me your paypal address and the damage + shipping.
    Thanks!!!
  10. #40
    Aug 2016
    1,370
    Yup, I see the paper. You owe me nothing, we’re all set.
    Shep
  11. #41
    Aug 2016
    1,370
    One last picture of the kids before they get divided up tonight. Think I’ve seen enough of these for a lifetime or a while anyway.....EL- your group of 10 will be shipped in a touch of baby powder that’ll wash off.
    Only one fail in the bunch/it was the first test on how many grams mix I needed to fill mold. First one came up short.
    Shep
  12. #42
    Apr 2012
    USA
    4,133
  13. #43
    Mexico
    9,018
    Finally got these home! Thank you Shep!!!! Will try to install one ASAP.
    Long story, but basically a lot of people did a lot of favors and everything I’ve had mailed to TX since February arrived to my place today.
    Also got all the wires ps2 recommended, I should be good to go on my Tri-Z ignitions.
  14. #44
    Apr 2012
    USA
    4,133
  15. #45
    N.E. Ohio
    2,005
    I could use a few of these, great idea.
