Results 1 to 13 of 13
Thread: Question about 200X lugs
    Apr 2018
    Gresham, OR
    47
    When I bought my 200X, the guy threw in a set of 9" aluminum wheels. The wheels fit the bolt pattern but the bolt holes are wider and are plastic lined. I was told that is normal and I all needed was tapered lug nuts. I got some tapered lug nuts but I am finding that the lug bolts are too short and the nuts only thread onto the bolts about 1/2 way before bottoming out on the wheel. Anyone know what hubs I need to switch to? Or do I or even should I replace the lugs with longer lugs? Or is there another solution?
    Williamstown PA
    5,825
    All 200xs were 4x110 bolt pattern. You need hubs off one of the following. anything per below.
    Trx250x 87-92
    Trx300ex all years
    Trx300x all years
    Trx400ex all years
    Trx400x all years
    Trx450r/er all years
    The pressed in hub bolts are longer. 200x ones were very short due to no using tapered lug nuts. When used g tapered one you need longer studs.
    Apr 2018
    Gresham, OR
    47
    Trx250x 87-92
    Trx300ex all years
    Trx300x all years
    Trx400ex all years
    Trx400x all years
    Thanks for the info. My TRX300ex hubs arrived the other day and I installed them today. Mounted the new Ocelot P336 tires and 9" wheels. Really like the look and the wider stance.
    Nov 2019
    Florida
    1,048
    I have the same issue, I just picked up some D.I.D. gold wheels and the wheel studs are too short and I need tapered lug nuts.
    Instead of buying hubs (I have a press) Is there a longer wheel stud that can be pressed into the stock 200x hubs?
    Also does anyone have a size or part number for tapered metric studs?
    I have the same issue on my 85 Big red (wheel spacers factory lugs are too short)
    I would prefer to just swap out the wheel studs.
    Thanks
    MrC.
    Nov 2019
    Florida
    1,048
    Oh crap, is the front hub different 200x vs 250r?
    I have an 11inch gold enkei rim but the pattern is bigger than my 200x hub. Crap! That's what I het for not checking.
    Options? Different hub or different wheel?
    to add another problem my 2 inch spacer wont fit the OE 8 inch wheels.
    Mrc.
ID:	262803   Click image for larger version.
    Carthage NY 250r rules
    2,355
    The front rim you have is 3rd gen 250r. The bolt pattern is smaller than 83-85 200x. It will be cheaper to buy a set of rear hubs like listed above than buying new studs.
    250r rules
    Nov 2019
    Florida
    1,048
    Wow, Thank you.
    As for the front hub, would a gen 3 250r hub fit my 200x?
    or should I look for a different rim?
    If I scrap the whole plan, what wheel spacers would fit my 8in factory 200x wheels?
    Thanks
    MrC.
    2,355
    You can get an 86-87 200x,85-86 350x or 85-86 250r front hub for your rim.Or get 83-85 200x or 83-84 250r front rim for your hub.
    250r rules
    Jun 2013
    Oceanside, CA.
    614
    The 200x 8" wheels are unique as the inside diameter of wheel is smaller than all others. Have the outside diameter of the spacers you have machined smaller.
    "HJ" Name:  oldfogey.jpg
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    Nov 2019
    Florida
    1,048
    Thanks guy, this is my first rodeo as you can tell.
    I have even considered having my factory OE 8in wheels power coated (gold) and sell the gold wheels I have.
    Do all the hubs listed in the beginning of this thread give the same increase in Width? or would one give more
    than another?
    MrC.
    Nov 2019
    Florida
    1,048
    ok,
    I opted to buy a new front rim 83/84 gold 250r and a pair of 300ex hubs and 8 flat lug nuts with coned shape washers.
    Thanks for all the help.
    MrC.
    Nov 2019
    Florida
    1,048
    Quote Originally Posted by atc300r View Post
    ATC300r, I wanted to come back to this thread and thank you for your incite and help, I got a new front rim that matched my currant 200x hub and a pair of new 400ex rear hubs along with some cone washers and lug nuts, it all fit together perfect tonight, I am just waiting on my rear tires. Thank you again.
    MrC.
ID:	262908   Click image for larger version.
    2,355
    MrC.Glad to help.
    250r rules
