Forgive me if this is a stupid question, but I would really like to learn.
I purchased a 350x and did an oil change. Used Valvoline wet clutch 10w40 motorcycle oil. No issues. I pulled the plug after a warmup, let it drain and added more oil through the dipstick area on the crankcase.
Here are my questions:
Does the 1985 atc 350x use transmission oil?
If it does how do I change it and what should I use?
The 350x uses an oil cooler and not a radiator. Is this drained when I change the oil?
I really appreciate the help.
