Ok guys, I give up, kinda, I never give up, but I am asking for help.
I can not remove right side the cover to replace the rear brake shoes on my 84 200es, i have all the cover bolts out, the water drain bolt out, the brake arm off, the 2 axle nuts off, the seal to the cover off and the copper shim off.
The cover spins with a tap of a
, but does not come off, i have pryed a little all around and different side at the same time but no. I is diffenitlly held on from the center either from the drum or bearing that's froze up IDK.
If I turn the brake arm pivot it will lock up the cover not allowing it to move, so I think the shoes are set inside the drum and that's whats holding the cover on?
#27 sir-clip, I do not see one on my machine, All I see is #4 the collar. and a #22 bearing
Thanks
MrC.
