Results 1 to 7 of 7
Thread: Need help/info about Big Red wheels/front hub
    yz96 is offline New to the board Arm chair racerNew to the board
    Nov 2017
    New York
    24
    Hey guys, I have an '84 Big Red 200E parts bike, and an '85 250ES parts bike.
    From what I understand, the front and rear wheels are the same size and offset, meaning you can use a rear wheel on the front if you have to... correct?
    Now is this true for all years 200 and 250 (Big Reds) also? For example, will a 200E rear wheel fit on the front of a 250ES? I don't have access to them right now so I can't check for myslef.
    Basically I want to use a rear wheel from the 200E on the front hub of a 250ES. To me, from pics I've seen online, it looks like the 250ES front hub rim mounts are offset to one side more, but maybe not.
    Any help is greatly appreciated, thanks!
    Apr 2014
    Edmond, KS
    2,591
    One thing that may help your research is that the 1984 Big Red was the 200ES. The 200E was in 82 and 83 and had a chain drive.
    Nov 2017
    New York
    24
    Ooops, you're right, I messed up. It's a 200ES. Thanks!
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    The wheels are not interchangeable between 200es and 250es models. The 200es has a 4x150mm bolt pattern, whereas the 250es utilizes a 4x110mm bolt pattern.
    Nov 2017
    New York
    24
    Ahh ok, damn! lol Thank you!
    May 2009
    S.E. Michigan
    1,251
    Wheel nuts are also different. Flat up through the 84, tapered seat on 85 and later.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Dec 2015
    S.E. Louisiana
    28
