Results 1 to 12 of 12
Thread: This cylinder still okay to use?
    Oct 2018
    Weeki Wachee
    77
    Hi all, my Tri-Z 250 seized up do to a center case air leak that was found, it did some damage to the lower part of the cylinder. I was going to get it bored out, is it okay to use it like this?
    glendive, montana
    1,822
    I wouldn't, just on the off chance that it breaks off and does a ton of damage to your crank. re sleeving is expensive but worth it compared to what you might spend with it breaking off. also a new sleeve will bring you back to stock piston size that will allow for a longer life span of the motor
    The Open Road
    4,736
    I agree with Muthey^^^
    Resleeve it or get a different cylinder.
    Mar 2020
    Denver Colorado
    43
    Tig it closed and file it. Magnaflux if youre skeered.
    Mexico
    9,020
    The stock liners in those engines were made as cheaply as possible. You can get a new LA Sleeve liner, labor and a fresh 68mm bore and a piston to match for about $400. In the long run it's cheaper that buying a used cylinder off eBay.
    devore,ca
    1,043
    Don't some of the big bore kits have that part of the cylinder removed ?.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Oct 2018
    Weeki Wachee
    77
    Quote Originally Posted by Maynard James View Post
    Yea I talked to the guy that is going to bore it out, he said he will just smooth it and it should be fine.
    Oct 2018
    Weeki Wachee
    77
    Any thoughts about the cylinder head? It took a pretty good beating. Not sure if this can be sanded out, or it would take too much off being how deep some of the nicks are. Im having trouble finding a nice head that is in good shape.
    The Open Road
    4,736
    That dome needs recut, not sanded.
    Find a reputable shop who does two strokes on the regular and ask for a quote to recut the head.
    Deep dents, dings, gouges in the head can cause detonation
    Oct 2018
    Weeki Wachee
    77
    Will the 85 YZ250 head work the same with a tri-z cylinder head gasket with no issues?
    Mexico
    9,020
    Quote Originally Posted by rmcollector View Post
    It will bolt to the cylinder and the gaskets are close, but the coolant spigots are in different spots, so no, the YZ doesn't work. Keep watching eBay, the Z heads come up regularly, you'll pay $50 to $100 for a nice one.
    Oct 2018
    Weeki Wachee
    77
    Oh ok I was wondering about that, yea I actually just bought a pretty nice Tri-Z head for $40 bucks earlier.
