200x Help needed
Anyone have a wiring diagram for a 83-85 200x? I hooked up everything and now the switch that worked on busted up wiring diagram, won't work.
I bought a working brake assembly from someone and now I have bled it and still no back brakes. What could be the problem? I pump it and nothing happens? It will pump the fluid and air out of the bleeder valve, then still no brakes. Weird, seems like the master cylinder is working fine but maybe it is the caliper?
Thanks for the help.
06 Yamaha Bruin 4x4
04 TRX Rancher 400 AT 4x4 GScape
86 ATC 250es Big Red
84 ATC 200s (31 yrs running strong)
13 F150 4x4 SuperCrew 5.0
00 Excursion V-10 lifted with 35s
____________________________
Gone
07 CanAm Outlander 650, 05 TRX 450R, 85 ATC 250r, 01 Kawasaki KLF Bayou 220 , 02 400EX, 85 ATC 350x, 84 ATC 200x, 85 ATC 350x , 98 KLF Bayou, 86 ATC 250r
