Thread: 1984 Big Red 200es No Spark
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    I bought this thing a few years ago in great shape. It would not start when i bought it. A new spark plug fixed that. As the years went by with very little use we noticed it would run great with a new plug, sit for extended periods, and then it needed a new plug to get started again.
    If we worked with it for a couple days it would start and run great, park it for awhile and no spark, new plug and it would run. Lots of new plugs.
    Now... A new plug won't fix it. No spark.
    I have done most of the basic trouble shooting to include a new ignition coil/plug wire, testing the ignition and kill switch etc.
    Before i start "shotgunning" parts at it i thought i would ask you folks.
    What causes a machine to go through spark plugs???
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    6,798
    The 84 model has a one year CDI box and they are known to fail . Luckily they are still available new from Honda . Part is not testable .
    Can try tapping on the CDI and see if the spark comes back .
    Can be many other things as well but like I said it’s a common problem with that year machine .
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    Thank you for the input,
    I suppose it could be bad coincidence that the plugs were going bad as the machine runs rich because i put to much gear oil on the the air cleaner.
    Just all out no spark...
    I will try partzilla as Honda of East Toledo seems to be closed.
    Dec 2019
    On the moon
    63
    For troubleshooting, take measurement readings of all your main parts. For a bike that pops spark plugs, most likely I’d say it’s your carb set up. Improper combustion will cause plugs to foul up. Aside from that, you could have a intermittent spark issue. I’d check all connections, measurements, check the carb for cleanliness. Also pop off the pulse generator cover and ensure it’s properly gapped and clean
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    Thank you fellas,
    I picked up a new OEM CDI from Partzilla. Now I have spark, and a good running machine again.
