Results 1 to 8 of 8
Thread: To bore or not
    Mar 2015
    madison ca
    9
    To bore or not
    So got the engine pulled apart and the piston is definitely shot. Cylinder wall is scored but not as bad as the piston. If I bore the cylinder do I need to have the combustion chamber cut bigger too? If I go bigger bore do I need to swap for a bigger carb?
    Sent from my SM-S737TL using Tapatalk
    Bore it. You never said what it was. And you don’t need to open the combustion chamber on 4 strokes.
    Mar 2015
    madison ca
    9
    It's a 200x. Is there a pretty noticeable difference in power from stock to say .030 over? Any other components that should be swapped to accommodate the bigger displacement?
    Tionesta, PA
    5,747
    Boring is not for performance gains - it's to get things back in spec and round (so to speak). People always confuse "Boring out" with "Big Bore" - two different animals. Big bore is significantly larger piston and generally a hogged out cylinder with a new larger sleeve. Boring out is just cleaning up the existing cylinder sleeve to true it up and make it round again. Have a machine shop measure it to see if it needs bored. You want to keep the bore as small as possible, for future boring.
    For example - if this is a 200X - stock bore is: bore 65mm x stroke 57.8 = 191.798 CCs. Now say you bore it .030" over - now your piston has a bore size of 65.75mm, thus going from 192CCs to 196.249CCs. So essentially you are only gaining 4CCs - not very much. A big bore 200X kit will take you to 250CCs or so - depending on what you can find.
    Telling people you have a bored out motor, and thinking that is a performance mod is something I hear people talking about and it makes them sound like they don't know what they are talking about. Big Bore is totally different - and about 5 times more expensive.
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    a bore out will not net you much for performance. I have a 250es that i just put back together a week ago, its bored 20 over, There is no noticeable gain. I did not change any jetting or the exhaust, completely stock just bored out. If you want power go with a big bore, high performance cam, carb and exhaust. If you want stock power and a fresh engine, just bore it out. You definitely will need a new piston. What happened to the engine for it to end up like that?
    Mar 2015
    madison ca
    9
    Thank you for educating me. Growing up I always heard guys talking about their bored engines, now it makes me wonder if they actually did big bore kits lol.
    Bought the bike about a week ago and I can only assume the previous owner ran this thing with little to no oil. He was the questionably sober type, and I dont mean booze. Looked like he's chased a few white dragons if you know what I mean.
    Aug 2016
    East of Worcester ma
    1,373
    If this is for the 86/87 Honda 200x be sure to get (when your ready) a-
    86/87 piston
    Or Honda fatcat
    Or 86-88 Honda trx200sx piston/ rings
    While your in there:
    Timing chain/ possibly guides
    Atleast change out the valve seals
    Do not use any silicone- try to get ahold of oem gaskets again the above bikes top end gasket kit will fit yours
    Shep
    Tionesta, PA
    5,747
    Quote Originally Posted by sdmyers13 View Post
    I hear people talking about "bored out motors" as a performance mod constantly. It is a pet peeve of mine. When I hear them talking about it, I normally stop listening right afterwards.
