84’ Yamahauler 200EL carb questions
Hello,
As stated in the title, I have a 84 Yamahauler 200el. The carb is a Mikuni VM22SH i.d. 24w01.
The three wheeler currently will start in one pull (electric start doesn’t work, that’s my next project)
It idles good when in warm conditions but needs choke 1/2 on, will not run without choke. Seems to not want to hardly idle if A little cooler in the am. When I give it throttle, you have to ease into it and feather it to get going. Wants to die if you draw throttle too fast at all from stop or moving. I did a basic carb clean but am looking for some guidance on how to adjust these carbs correctly. Also has quite a bit of blue smoke while running. Thanks.
1984 Yamaha YTM200
I keep my throttle tight
