Thread: Noob with an ATC90 needs advice from the experts
    Apr 2020
    Winchester, Virginia
    3
    I'm doing a top end refresh on an ATC90 that was stored over 20 years ago. While cleaning up crusty engine parts I noticed the left engine case is broken right above the sprocket. I've read that this is a fairly common issue on trikes, caused by snapping the chain and having it bunch up and punch thru the case. The broken web is in the 10 oclock area if you're looking at the sprocket. (Forgive me, but it appears my pic is going to post sideways...)
    There's no oil residue in this cavity or in the mating cavity on the left engine cover. It's the area that the neutral indicator shaft passes thru. Is this a "dry" area inside the motor, or will I have a huge oil leak once I get it running?
    If it must be repaired, what's the best way? JB Weld? Welding a new web into place? I looked into replacing the engine case, but it looks to me like the whole engine's innards are assembled into the left case first - thus requiring a complete engine teardown.
    Thanks guys!
    Butch
    Apr 2020
    3
    Surely someone has run into this problem before, and has the right answer for me...
    May 2013
    Brownsville, Tn.
    1,271
    Yes common issue. I would just JB weld it.
    Also keep a Click image for larger version.
Name:	case saver 4.jpg
ID:	262410look out on ebay for a case saver. It will save you some trouble in the future.
    * Nicholson 500 Race Bike *
    Apr 2020
    3
    Thanks for the advice - JB Weld it is then. That case saver's a great idea - I'll keep an eye out for one (or fab one up!)
