Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 63
Thread: 86 200x Build
  1. #31
    Apr 2020
    New Zealand
    81
    Thanks mate, really struggling with gaskets and oil seals now so I’ll reach out to him. CMNSL is sold out of the left as of now - before I got in.
    Also, can someone help me ID this head. Is it a powroll head? The gasket mating surface is machined down from what I can tell.
  2. #32
    Apr 2020
    New Zealand
    81
    Got a little more done on this one. Gaskets finally arrived tonight so I should have the motor in next week.
    Back end is all done except I need a disc and the axle anti fade nut if anyone has tips on where to find them.
  3. #33
    Apr 2020
    New Zealand
    81
    Engine in the frame. A few touch ups to do where I hamfisted the install.
  4. #34
    Mar 2020
    Palestine, AR
    398
    Awesome. Great work. Very interesting to watch it come together
  5. #35
    Nov 2019
    Florida
    1,053
    Looks great, I never realized how different the 85-86 engine was. Impressive.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
  6. #36
    6,810
    A trx 300ex / 400ex and 400x ani-fade nut will work . Still available new from Honda
    Just buy the complete assembly .
    And their are plenty of used ones on eBay if your on a budget
    https://www.partzilla.com/catalog/ho...le-drive-chain
    https://www.ebay.com/itm/33396976573...oAAOSwGFdgbMAn
  7. #37
    Apr 2020
    New Zealand
    81
    Absolute legend. Thanks.
  8. #38
    Yep, those seal kits don't fit correctly.
    I just got in all my seals the other day, I'll list some in Classifieds at some point. I have every seal for the 2nd gen 200X and the 350X in stock.
    I guess you figured out your shift forks? (sorry, very busy lately) but most Hondas have a stamp in the castings - L / R
    Coming out great!!
  9. #39
    Apr 2020
    New Zealand
    81
    Coming out great!!
    I got one of your kits on eBay. On its way over now, hopefully be here this week.
    Carb coming from Mickey Dunlap as well.
  10. #40
    Willamstown PA
    5,822
    TRX250X TRX300EX TRX400EX TRX450R axle lock nuts are all the same and will fit. I personal have never had luck with anti fades. They looks cool as poo but everyone i have had or seen has be worn out. I only run 250R OEM rotor hubs and rotors now. The old durablue posi locks were the best i thought. As of now i run OEM lock nuts but electrical tape them shut. I was told about that trick maybe 13 years ago. Its worked and helped to keep junk out and them come apart stupid easy. Also helps if you invest is a huge adjustable wrench and not a pipe wrench to take them appart.
    Hope that helps maybe.
  11. #41
    Crap, I'm sorry! I haven't been here to check PM's for weeks or I'd have helped.
    I can DM you my phone number or Facebook info (if a PM there doesn't cost you like a text message would).
    Pretty much anything 2nd gen 200X I have my hands in...
    Build looks great!!
    PS - Bud, I would NEVER run SS bolts in the 200X cam holder, they will probably be fine but SS is really a cosmetic thing and I don't use it anywhere I worry about needing to be strong or stay tight, it's a weak SS that's used in those fastner kits.
  12. #42
    Apr 2020
    New Zealand
    81
    86 200x Build
    All good, oil seal kit worked a treat.
    The stainless is all 316 from my local shop, but point taken.
    I received the 300EX axle jam nut from ebay, but it doesn’t fit unfortunately, its a lot bigger than the axle spline and won’t lock down onto the lock ring.
    Sent from my iPad using Tapatalk Pro
  13. #43
    Apr 2020
    New Zealand
    81
    Bit more done on the backend. Still piecing things together slowly.
  14. #44
    The Open Road
    4,736
    Looks fantastic
  15. #45
    Apr 2020
    New Zealand
    81
    86 200x Build
    Shock in, oil cooler routed and electrics on. Waiting for the carb and rear wheel lock nut now.
