Results 1 to 15 of 19
Thread: Noisey 200 engine
    Dec 2019
    On the moon
    63
    Noisey 200 engine
    Hi guys, just finished my 200M build, very happy with how it turned out. I got it running perfect, through some new fuel, lil bit of seafoam in the tank and it runs strong. Took it for a spin and am liking how everything works. The only thing concerning me is that the top end sounds a little noisey. Small rattly noise / ticky type of nice thats continuous.
    Where do i go from here? do i need to check / adjust the valves? What about the timing chain? I am not sure how to do it yet, will look through the manual. Is it very simple, and anything else recommended? I just gave the bike a 10w40 oil change using castrol motorcycle oil.
    Cheers
    Jun 2009
    Tunkhannock,Pa
    904
    Also check your oil pump and make sure your getting proper oil flow to the top end
    Sent from my moto z4 using Tapatalk
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Dec 2019
    On the moon
    63
    Quote Originally Posted by RodKnockRacing View Post
    How is that done? Much too checking oil flow to the top end? Thanks.. nice name by the way im sure youll come in handy here lol
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    I have never encountered a honda 185 or 200 that did not have some top end tick. I would bet money on the cam chain being loose, they have to be manually adjusted. Ill post a link to a good youtube video that shows how to do it. Ill also post the video of valve adjustment. They are both fro a 200s, but the adjustments are the same. The only change from the 200s to the 200m is the electric start.
    cam chain- https://www.youtube.com/watch?v=eAblGUpxBqM
    valve adjustment- https://www.youtube.com/watch?v=IHeIXalJ9N8
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    Dec 2019
    On the moon
    63
    Quote Originally Posted by Homeless Dave View Post
    Perfect thanks alot, just skimmed through the manual too, I might need to get one of those offset wrenchs. This bike i've been fixing up was parked for 25 years so it is definitely in need on some maintenance.
    I just went through the bike and painted the frame, and got the brakes and stuff working. I need to find a mini inline fuel filter, tried using a lawnmower size one but its too big and clunky to fit there properly.
    How is the oil to top end tested? Don't see that mentioned in the manual.
    Jun 2009
    Tunkhannock,Pa
    904
    Service manual will come in handy the oil pump process is a little involved. In my opinion ever 200 pump should be service with new o rings and gasket and cleaned, rotor, gear, and shaft checked. If not and it's not flowing u will destroy your entire cylinder head. To check flow some people loosen the back right cylinder head nut while engine is running, and see if oil is coming. I just pull the front valve cap and shine a light you should see oil. If you see gray metallic oil. Is a sign of no flow or improper flow. Hope This helps
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    Dec 2019
    On the moon
    63
    Excellent thanks, Will do this all tomorrow and report back to what i find! Super pumped to start riding this week, just want to make sure the bike is fully up to par before i hit all the trails.
    Apr 2019
    South Dakota
    255
    +1 on making sure the top end is oiling. Got a lt125 that didn't oil and the cam bearings were destroyed. it was so bad when the engine turned over it sounded like rod knock, but it was the camshaft flopping around!
    Ill get some pictures of it tomorrow.
    Jun 2009
    Tunkhannock,Pa
    904
    Yep been there before with my first 200x build over 10 years ago it's how I learned
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    Arkansas
    2,447
    That was a great YouTube link for the camchain adjustment. The guy's speech is clear, the camera work is steady and focused enough, and he gets right to the point, but most importantly, he covers what many people new to the 185/200 ATCs would have no clue about if they followed the manual. Probably the #1 thing not cleared up by most owners who are otherwise on spot with maintenance.
    Dec 2019
    On the moon
    63
    Yeah the links are great. I'm trying to track down one of those offset wrenchs for the valves and also the 3mmx0.5 bolt needed. Found one but its too short. Otherwise it looks pretty simple to do, funny how the valves are checked by feel mainly, was hoping to get my feeler gauges dirty haha
    Apr 2019
    South Dakota
    255
    you don't have to have specialty tools do adjust valves. a regular open end wrench will work. You can use feeler gauges to set valves, it will be more accurate. As for the bolt, i took the taillight lens screw out of a junk kawasaki kz motorcycle and it worked, not sure if it was the original screw though (it had 2 different screws holding it on). One thing to be careful of, is when you take the flywheel timing cover off, dont strip out the top of it. Those covers have often been on for years and like to stick, so be mindful of that.
    I also promised some top end destruction pictures...
Name:	cam bearings.jpg
    Dec 2019
    On the moon
    63
    Well, can’t get that flat head inspection cover off. Doesn’t want to budge. Not really sure what to use, the flathead screwdriver is small compared to it. Tried using a wide Chiesel but no Luck lol. I popped the valve covers and there’s lots of oil visible in there without the bike even running.
    Apr 2019
    South Dakota
    255
    You can find top dead center another way. Rather than removing the cover, you can take out the spark plug and remove the valve adjustment covers. Then, get a piece of wire (or anything long and thin) and insert it into the spark pug hole. Turn the engine over by hand until you can feel the wire get to the highest point, make sure that neither valve is open (should be able to feel the free play in the rocker arms). This should get you to the point of being able to adjust the valves, however, i recommend trying to get the cover off before resorting to this. For trying to get the covers off, i have a wide wood working chisel that i ground the edge off of so it is flat and it works really good.
    If you are super desperate, get a small and tap on the cover (be very gentle, you can shatter them..) and then try to unscrew it, i have had luck with that before.
    Dec 2019
    On the moon
    63
    Okay will try this tomorrow, got a lil mad at it earlier and gave up haha. For a simple job i didn't expect to get held up on step one. I'll grind down a chiesel or piece of flatbar or something. It was probably never off before. I gave it a few good smacks earlier and tried twisting but no go. Valve covers were not very tight, didn't even have to put much pretty to spin them loose. I was thinking i needed the special tool for adjusting the valves but after looking at it earlier, it's pretty easy to access.
