Results 1 to 3 of 3
Thread: 1988 Yamaha bigbear 350 boggs down with no power
    Apr 2020
    Ontario Canada
    Hi everyone,
    I was on this site about 15 years ago but forgot my original login. Now I am Happy to be back again.
    I have a 1988 yamaha bigbear 350 4x4. It was running fine, then all of a sudden, my exhaust would glow red hot and would loose power. It will idle no problem, but as soon as you roll the power on, there isnt much there.
    I have verified the following to be within specs.
    - compression is good (according to a good friend)
    - leak down is very acceptable.(according to a good friend)
    - timing is right on. (According to a good friend and I have verified myself)
    - cleaned air filter
    Here is what I have replaced so far:
    - carburator intake boot
    - carburator (chinese carb off amazon)
    - spark plug
    * I still have the original Mikuni carburator, but I had to drill out the low speed air screw as it was jammed solid in the housing. I have not purchased a carb rebuild kit for it yet, but it is an option I am willing to try. Just keep in mind that the problem started even before I changed the carburator.
    What I have noticed:
    Multiple sparks during complete cycle ( much more than just 1 spark per cycle)
    What I have also tried:
    - removed all of the handlebar and thumb warmer electrical that were installed by previous owner.
    - baked the CDI In the oven.
    I have recently purchased another CDI off a 1987 bigbear and waiting for it to arrive.
    If this doesnt solve the problem, I will replace the coil and/or stator/pulse generator next.
    I dont know what else the issue could be.
    Has anyone ever had this problem before?
    Please help!
    Thank you,
    Paul
    fingerlakesny
    2,834
    Sounds like a carb issue to me. i have had a few of those models and never had a problem.... those aftermarket carbs imo. are junk.
    250r dust runner
    6,788
    Make sure your exhaust is flowing freely .
