Results 1 to 7 of 7
Thread: Is there a 1982 ATC200S cylinder option?
    Dec 2009
    illinois
    1,765
    Got someone needing a new cylinder for a 1982 ATC200S, is there any new cheaper cylinder kits made like the do for The other ATVs?. New aftermarket Chinese cylinder?. I know they make them for the Rancher and recons etc..
    6,819
    Their was a 180cc kit available a couple years ago that worked great . I bought about 6 kits , the seller sold out and that was it !
    Your cheapest option is to just over bore with your old cylinder .
    Arkansas
    2,447
    I have been eyeballing the heck out of some on EBay. A lot sold but no feedback on if they actually fit what they claim. https://www.ebay.com/itm/Cylinder-Ki...ox!72058!US!-1
    What's immediately noticeable is they have and external cam chain adjuster port. If a manual adjuster would fit there, shoot yeah, otherwise it'd need plugged off.
    The other thing is they look like the first gen 200X cylinder, with the larger fins.
    They also claim 65.5mm is 223CM3.
    Who's going to be the guinea pig?
    Dec 2009
    illinois
    1,765
    I'm thinking of just re- sleeving the cylinder... I heard if I put the cylinder in the oven at 350 degrees for 20 minutes .. the sleeve will be easy to remove
    Dec 2009
    illinois
    1,765
    Can anyone point out the correct sleeve for the 1982 ATC200S on eBay or somewhere?
    Dec 2007
    Quebec,Canada
    1,014
    But,thoses cylinder are everywhere...why not just bore your cylinder?
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    DSHOT59's Avatar
    DSHOT59 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    sayreville nj
    156
    And there was no 200s in 82.The s started in 84 I believe. The early ones were just called the atc 200. Just say'n
    No trike left behind
    1983 Ytm 200
    1983 Honda 200
    1982 Honda 185s
    1983 odyssey fl 250
    1987 yz 250
