Thread: 84 atc 250r
    Feb 2020
    fenwick
    9
    84 atc 250r
    Hey guys, wondering what the options are for replacing the rear axle on the 84 250r. Hoping there is something that may interchange. Any advice will help
    N/A
    5,818
    83-84. If not you'd need to have new swinger made and run a flipped axle off somthing else. Thats gonna cost. Durablue still make new 83-84 250R axles.
    Feb 2020
    fenwick
    9
    Ok thanks for the advice, will check out pricing on the Durablue, from what I’ve read I guess it could be the hub that is bent so I will try and switch tires around to see if there’s any difference, she hops down the road right now, don’t ride much road but have to get from trail to trail...
    Slidell, LA
    4,738
    Oem or durablue are your only options. Plan on spending about 700 on the durablue.
    Apr 2014
    Edmond, KS
    2,591
    If switching tires doesn't help, try switching the rear hubs from side to side.
    Feb 2020
    fenwick
    9
    Thanks guys, actually found a machine shop with a machine just for straightening axles if that turns out to be my problem. The trike hops down the road right now, I barely notice anything off-road,(only on the road between trails). I will have to look into the hubs and rims abit better and switch them around see exactly what is bent. Cheers thanks, keep you all posted
