Results 1 to 8 of 8
Thread: Stuck caliper and master cylinder piston
    Feb 2020
    US
    57
    Hey guys. I'm starting a revitalization project on my 85 200x. It sat mostly idle for 12 years in a shed on a friend's property. Digging into the brakes, and have stuck pistons on both front and rear calipers and the rear master cylinder. Any ideas from the gurus out there?
    Sent from my SM-G960U using Tapatalk
    6,817
    Can force them out by using a grease gun screwed into the banjo bolt hole .
    A little heat if needed .
    Their are special pliers for removing caliper pistons .
    Mexico
    9,019
    Compressed air can work too, but make sure to protect your eyes and wrap the caliper with a towel or rags before you blast air into them. I like to push them in a little with a C clamp to break them free first.
    Apr 2014
    Edmond, KS
    2,591
    I just ran into this on a 1983 Goldwing. I did like El Camexican said and used a c clamp to push them a little bit first. I got the pistons to move out a little bit with compressed air. I sprayed a little WD-40 on them before I pushed them in again. Then I sprayed some inside the caliper through the banjo bolt hole. I did this thinking that it would help lube up the old, dry seals. It seemed to help. I worked them back and forth several times.
    The Open Road
    4,736
    I loosened the bleeder on calipers, took a grease gun with and plugged the end right onto the nipple in the bleeder and pumped grease in there until the pistons popped out.... Then I cleaned the grease out of the caliper and reinstall new seals.
    Feb 2020
    US
    57
    Thanks for the tips.
    Feb 2020
    US
    57
    Thanks for the advice. I was able to push them in a bit with a clamp.
    Feb 2020
    US
    57
    Thanks for answering. I'll keep after it.
