Thread: Aftermarket carb
    Feb 2020
    US
    57
    Aftermarket carb
    Debating what to do about a carb for the 200x revitalization. I have the original 24mm keihin from the x on my 185s and it's running really well. Would like to leave it on there. I do have the original 22mm for the 185s, minus the bowl and float. The keihins on the Hondas were a proprietary design and I hmm haven't seen yet a carb that mounts to the stock manifold.
    Is there an aftermarket carb that will adapt to the intake on the 200x?
    Sent from my SM-G960U using Tapatalk
    Willamstown PA
    5,824
    I ran a XR200 carb, might be able to run a CRF230 carb but never dug into it.
    Nov 2019
    Florida
    1,054
    The P.O. of my 200x put on a 22mm Mukuni, it runs good.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Slidell, LA
    4,738
    Quote Originally Posted by agedatc View Post
    Put the 24mm back on the 200x. Find a used vm 22 for the 185 and rebuild it. I could suggest some different carbs but unless you are ready to tune all day then avoid it and just go back oem. You’ll thank me later
    Feb 2019
    Western NY
    50
    I had problems trying to get the original carb on my '87 200x cleaned and adjusted properly. I bought one of the crappy Chinese carbs from Fleabay and it works very well. I've had it on there for about 4 years now with no issues. If I recall correctly, it was something like $30.
    1987 Honda 250SX
    1987 Honda 200X
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    I bought one of these a few weeks ago and was very impressed with how much better quality that it looked compared to the few other chinese carbs that I had bought. The carb body, on this one, above the bowl looks like it is cast rather than sintered metal and I think that makes a difference in how well it performs. I put it on an old 200M that never ran right and it started up first pull and idled and ran like a brand new ATC. It does not have the bracket or spring for the choke cable, but I transferred them from the old carb and it fits and works great. A lot finer choke adjustments with the cable. I bought two more and I am about to put them on 185's that need them. Since they come with a petcock, $23 shipped with Amazon Prime seems like quite a bargain. The spigot on the petcock aims down, but I think I will learn to like that.
    It is marked PZ27 by the bowl seam and JIN WEI on the carb body at the slide area.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Feb 2020
    US
    57
    Quote Originally Posted by JustEnough View Post
    23 bucks? Might be worth it for my 185.
