Thread: 350x timing chain trouble
    Mar 2020
    Tomahawk WI
    23
    So last winter one of my 350xs locked up on the ice. I just dig into it today and I’m wondering if there’s an easy way to remove the timing chain if my piston is seized. I got one of the cam gear bolts out but the other one is hidden. I tried to spin the motor with a breaker bar and got it to budge about 1/8th turn but I can’t turn it the other way because the flywheel bolt loosens. I’m just wondering if anyone has any tips/tricks or am I going to have to cut the chain and put a new one on?
    Aug 2006
    new hampshire
    914
    I had the same problem and ended up cutting the chain. Good luck with the tear down.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Yep, just slice it with a cut off wheel.
    If you need a new OEM chain, I have a few kickin around...
    Mar 2020
    Tomahawk WI
    23
    Kind of funny how I ended up doing this but the bolt was almost to the point where I could get to it so I ground a wrench down on my bench grinder until it fit.once I got it loose enough the cam gear pivoted enough to slip the chain off and pull the cam out. I only didn’t want to cut it because the timing chain was just replaced last year. When I got the motor opened up I found the piston is melted, the connecting rod is bent and snapped at the big end and there are needles from the bearing everywhere in there. Cylinder is cracked too 3-4 inches long of a crack. Currently in the process of looking for a good spare motor or a bottom end and a jug. Then I can still rip my 350 and split the cases on the old bottom end when I have time.
