Results 1 to 3 of 3
Thread: 1980 Honda atc 110 no start no spark help please
    May 2020
    British Columbia
    44
    Posted before here about my 125 but recently found a 110 that I bought. Doesn’t run right now. Not getting spark. I bought a new ignition coil installed but no spark still. Had only old spark plugs but I bought two new ones and still have to try that out , so that could be it possibly. Picking up new point assembly tomorrow to swap the old one out.
    If that doesn’t work. Is there any other common issues with these models with it not starting? I just read tonight about the kill switch and I’m bad with wiring. If those things don’t help I’ll wire the two starter wires together to see if it’s a bad switch.
    Carb is cleaned, gas tank cleaned ,
    Thank you
    6,798
    The factory coil has the condenser on the side of the coil as one part .
    If you replaced it with China crap you will never see a spark . Put the factory coil back on , they very rarely go bad unless exposed to the elements for a long time .
    The most common issue with that year is the points , clean or replace them first .
    May 2020
    British Columbia
    44
    Ok thank you. I like to try and keep original parts so I’ll try that.
