Results 1 to 8 of 8
Thread: Atc110 knocking after cam
    Nov 2019
    Ohio
    Hey guys new to building engines, i tossed a cam in the other night and there is knocking happening. She starts up first pull, blows some blue smoke.. checked valve clearances at tdc. I think im doing everything correctly but if you have any ideas let me know! Thanks!
    Jun 2020
    John Fahey's sister's couch
    53
    You're not doing it correctly so get that out of your head. If it was correct it wouldn't smoke or knock.
    Valves must be adjusted not only at tdc but at tdcc. There is a top dead center twice in the 4 stroke cycle.
    Watch the intake valve open, then close, TDCC will come very shortly after that.
    "Tossed a cam in"... A new one? An old one? Stock, hi perf, what? Give more detail on your parts and process.
    Nov 2019
    Ohio
    Its a web cam never installed, ive never messed with a engine before figured this will teach me some, i did not even think about adjusting one then the other that is forsure one of the issues, i will try that right now thank you i appreciate it.
    Its a 83 110 with vm22, uni, and a dg exhaust
    Jun 2020
    53
    Quote Originally Posted by Mfstickies View Post
    Dont misunderstand... They get adjusted only ONCE, BOTH when the piston is at TDCC. You could very well have been on the exhaust stroke when you adjusted them. Did you install new rockers?
    Throwing expensive parts at engines isnt the best way to learn.
    You probably didnt time it right. Sounds like your piston is smacking the valve. Now you'll probably need a whole new topend.
    Nov 2019
    Ohio
    No i did not install new rockers or valves, i have piston n rings for it i just have not gotten it bored out yet for them yet
    Nov 2019
    Ohio
    Thank you fabio I appreciate it! I got it taken care of valves adjusted properly she fired right up, im sure i dicked up something a little bit but no knock, purs like a kitten just a little smoke so ill tear it down and check it out, i had the valves adjusted on the wrong tdc
    Nov 2019
    Ohio
    Nov 2015
    Davenport iowa
    1,144
    You said web cam, what size cam did you put in?
    1974 original 90 X 2
    1974 Original 70.
