Results 1 to 12 of 12
Thread: hi
    Jul 2020
    Australia
    16
    hi
    Hi from aus rebuilding a 185s
    Arkansas
    2,447
    Welcome. Will you post some pictures?
    Jul 2020
    Australia
    16
    [ATTACH=CONFIG]263840[/ATTACH
    Before
    Jul 2020
    Australia
    16
    Rear
    Jul 2020
    Australia
    16
    Getting there
    Jul 2020
    Australia
    16
    Need a tank and pick your brains a bit
    Jul 2020
    Australia
    16
    Lots of paint and parts
    Arkansas
    2,447
    Looking good.
    Those forks seem bent back, like someone smacked into something head on.
    Would be a good excuse to put the later 185S/200S suspension forks on it.
    Jul 2020
    Australia
    16
    Hard to find in aus should make it turn quicker ? is there a link for the electrics, manual not very informative want to put lights on it had none when I got it
    Arkansas
    2,447
    Quote Originally Posted by Cranky old man View Post
    Suspension forks won't make it turn any quicker. As far as lights, you can add anything you want, as long as it's below the stator output.
    Arkansas
    2,447
    I'm not certain if the wire colors are the same, but the wiring basically is. This is on the the 3wheelerworld home page, under 'Honda Wiring Diagrams.'
    If you don't have an OE headlight housing, the old style tractor work lights actually work really good.
    https://www.ebay.com.au/itm/MOTOLITE...AAAOSwZOBfB3SR
    Attachment 263844
    I used to run two of those on my 185, one spot and one flood. They were about 30 watts each, so I had the flood for low beam and the spot for high. They were very durable and long lasting, and the light output was better than an old OE headlight with a faded reflector.
    Attachment 263845
    They used to be easy to find and cheap, now, not so much of either.
    If you're wanting something a little more modern, I made a thread about the LED conversion on my 185.http://www.3wheelerworld.com/showthr...ersion-for-LED
    Jul 2020
    Australia
    16
    [QUOTE=ATC King;1512507]Suspension forks won't make it turn any quicker.
    No shortening the wheelbase should make it turn quicker with the electrics where do I hook the multimeter to test the generator
