Results 1 to 3 of 3
Thread: Proper way to adjust the pilot screw on a Honda 185s?
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    I was told that you turn it in until it starts to run funny, then turn it out until it starts to run funny (counting your turns) then split the difference and leave it in the middle of the two.
    Here is the problem, even though I maybe shouldn't complain, because it's running like a brand new machine, but:
    No matter which way I turn the screw, it still runs fine. I've even turned it in all the way, it still idles fine. Out 3+ turns, runs fine. It'll sit there and idle just fine for hours if I wanted it too.
    Should I just leave it at a base setting and forget about it? Anyone know how many turns out it came from the factory?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    Nov 2002
    Kirkville, NY
    3,831
    The Clymer manual says to let the engine warm up then set the idle, turn the piolt screw clockwise slowly until the engine stops running, then back it out one full turn and readjust the idle. The factory setting is 2 turns out. I would leave it at the factory setting if it doesn't seem to be makeing a difference.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    StangLX302's Avatar
    Jun 2003
    302
    Thank you very much.
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
