Thread: Need a little 185 clutch help.
    Nov 2019
    Florida
    1,048
    So I tore into the 1980 185 I recently picked up.
    the clutch was smoking and slipping, it did pull and ran really well just slipped
    So I ordered a clutch pack and springs, and tore it apart.
    Here is what I found, Forgive my ignorance of the proper name of each part.
    The bell is grooved a lot, is this normal for a 185? all the others I have done they are not this pronounced
    There is a large disc/washer/plate that use to have splines on the inside, the splines are now missing it was between the centrifugal clutch and the bell
    The clutch pack only has 4 friction disc instead of 5 like the 185s.
    Looking at the missing grooves on the centrifugal clutch, I am thinking it is shot as well
    First thing first, I don't think anyone has ever been in this engine. The splined large disc/washer/plate must be replaced, is the bell worn out? should I only put 4 new friction disc in or all 5?
    I have other 185s and 200 engines, I could pull the clutch/disc/bell and do a swap, if they are interchangeable parts.
    Any thoughts?
    MrC.
    Attached Thumbnails Attached Thumbnails 20200728_211552.jpg   20200728_211549.jpg   20200728_211657.jpg   20200728_211637.jpg   20200728_211719.jpg
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Nov 2019
    Florida
    1,048
    I did some searching and found out the washer/plate is called a clutch plate, it did have teeth on the inside, there was an updated version that is interchangeable. I just picked up a 84 200es big red parts bike the top-end is off, so I cross-referenced and sure enough the 1980 185 and 1984 200 share the same centrifugal clutch and its components. So looks like the new parts bike just paid for itself. Gotta love a parts bike.
    I will post so side by side comparisons tomorrow night after I do the swap.
    MrC.
    My Addiction
    86 350x
    84 250r "lucky"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    Grooves are normal, aftermarket brands of shoes actually make theirs a bit thicker to compensate
    Sometimes they are a file to fit deal.
    The drum is hardened steel so its not easy to weld up and return the face. NOS ones pop up every now and then.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Nov 2019
    Florida
    1,048
    Thanks BarnBoy,
    I was thinking the grooves in the drum must be normal, I couldn't imagine a rubbery shoe wearing away steel like that.
    I just had the lower end of a 200es come into the shop as parts, I snatched the whole drum/plate/centrifugal clutch, cleaned it and installed it into the 185.
    partzilla diagram says they both share the same part number for the entire drum and the internals of it.
    While I was there and had the parts, I replaced the clutch disc and springs. figured it wouldn't hurt.
    My major concern is whether or not the one way bearing was any good, wont know till I ride it and it gets hot. Waiting on a new petcock and seat cover and that one will be finished.
    MrC.
    My Addiction
    86 350x
    84 250r "lucky"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Jun 2015
    Oklahoma
    732
    Quote Originally Posted by MrConcdid View Post
    Thanks BarnBoy,
    MrC.
    If you shut it off and you hearing a whirrrrrrrrrrrr-clunk that means the one way bearing is bad. You can still get one new
    Da velder
    Feedback:
