Results 1 to 9 of 9
Thread: Carb Float height Adjustment help
    Apr 2014
    Upstate NY
    18
    I have a Kawasaki KLT 185, Ive been having problems with the carb (I think, Its skipping) So I tore it apart and am going through it, The book says float height should be 33 mm.... How is this even possible? The highest it can go is about that height, The second photo is me holding the float all the way up....
    What should I set it at?
    May 2009
    S.E. Michigan
    1,251
    I have zero experience with Kawasaki's, but there is an alternative method to use as a general rule if you don't have the specs handy. This also requires a carb with a float bowl drain on the bottom. If you connect a clear vinyl hose to the drain and run it up along the side of the carb, you can use it as a sight glass. Make sure your hose goes up a few inches past the float bowl. Open the carb drain and the fuel will rise up in the tube. I've read here and other places that a rule-of-thumb float level is to have the fuel level right at the seam between the float bowl and carb body.
    Of course, if you can figure out the measurement method like you are using, that is probably best. But in case you want another way, try the clear tube idea.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Apr 2014
    Upstate NY
    18
    Quote Originally Posted by wonderboy View Post
    I am assuming I can do with in a vise or something as long as fill the carb with fuel? Kawasaki made the carb annoying as heck to keep taking in and out...
    May 2009
    S.E. Michigan
    1,251
    The key is to hold it at whatever level it would be at mounted in the machine. In other words, if it is at a slight angle in the machine, then try to match it as close as you can when holding it in the vice. Otherwise, I don't see any problem doing this remotely. Again though, this is just a fall-back plan when there isn't another way. Hopefully somebody with experience actually measuring the float height can chime in and answer your original question.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Mexico
    9,018
    If this is your carb it looks like the float height is 19mm
    devore,ca
    1,042
    I always set them so they sit level with base of the carb.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Apr 2014
    Upstate NY
    18
    Its a mikuni V22ss.
    Apr 2014
    Upstate NY
    18
    Quote Originally Posted by BOB MARLIN View Post
    what do you mean exactly?
    Mexico
    9,018
    Quote Originally Posted by unitednations16 View Post
    Its a mikuni V22ss.
    I recall Mr. Sound was looking for parts for his and we concluded that it was basically the same carb as the Yamaha YTM 200.
    http://www.3wheelerworld.com/showthr...e-Fuel-Mixture
