Results 1 to 7 of 7
Thread: What Glue to Fix Helmet
    Jul 2002
    El Paso, Texas
    512
    The rubber lining around the opening to my HJC CL-X3 Helmet has come off after ~18 years of riding with it. Me being the guy that makes things last, I want to re-glue it and keep using it. I've been through a lot with that helmet. Any suggestions on the type of glue to use? I tried Shoe Goo II and it didn't hold... Thanks!
    Honda
    86 350X - Full Restomod
    85 250R - Legend
    85 Big Red - Clean Original
    85 Big Red - Custom
    Not Honda
    85 Yam Badger 80 - Kids
    99 Pol Sport 400 - Got it FREE
    Mexico
    9,014
    I've used plain old contact cement with decent results, but it will still pull off easily if tested due to the smoothness of the helmet's finish. Might want to try Crazy Glue.
    Arkansas
    2,447
    Maybe it's a sign to get a new one. Hang that one up for the memories.
    Helmets aren't meant to last a lifetime. UV light, environment, and body oils degrade them over time, to the point they may not provide the protection intended. It's not any different than construction hardhats, which often have dates stamped/molded into them. Protective gear also advances all the time.
    There are some really nice helmets available now. Removable (washable) liners are just about the norm, and ventilation has vastly improved on many. There has also been serious consideration to what they are used for, as in a helmet designed to protect MotoGP racers may offer less protection for riders at lower speeds where impact forces are lower and the helmet's interior may not deform under lower impacts. Helmets are also a one time use deal. Have a pretty good crash...toss it and buy a new one. Nobody is repacking automotive air bags like parachutes.
    Treat yourself to a new one. My first stop is the online closeout sales that many websites have. They're really thrifty for people who have and undersized or oversized head, because those are the sizes that usually end up clearanced.
    I use Shoe Goo on everything, and its an awesome product. It seems to be a mix of silicone, airplane glue and super glue. Gotta let it cure based on how thick you build it up.
    I put it on it being soft, but thick, it slowly rolls off when thick, so you have to watch the cure and rotate towards the area you want gravity to take the stuff.
    I've used this stuff for 40 years, great stuff!!
    Sent from my SM-N960U using Tapatalk
    Jan 2018
    California
    111
    3M weather stripping adhesive is designed for exactly that type of job, or plain liquid super glue. It will never come off again with super glue, if done properly. My neighbor showed me how he often uses super glue to do small jobs like that and the rubber can't be pulled off after just 10 minutes, but it is very easy to use too much and have it squeeze out beyond the rubber, which you would need to try and clean off right away so it doesn't damage the paint where you can see it. The weatherstripping adhesive dries slowly, so you will likely need to tape the rubber in place after gluing it with that until the glue dries.
    Jun 2015
    stonecreek ohio usa
    654
    Shoe goo is an amazing product
    N.E. Ohio
    2,005
    Seriously for a helmet that the DOT numbers beyond 5yrs of age on a less than $150 purchase? When it comes to valued helmets they become wall hangers. A $600 and up 5yr old maybe I’d fix ....I’m a cheap beat repeat on helmets like gear wear out and no matter what get funky.
