Thread: ATC200ES electric start issues
    Cape Town, South Africa
    111
    One of my ATC200ES has developed an issue with the electric start.
    When starting it will most times make a loud grinding/grating gear noise as if its slipping, noise seems to coming from the flywheel area.
    The bike does start, but sometimes needs 2 or 3 attempts where it used to start first time before the noise appeared.
    I have a few spare starters and solenoids I changed them out but theirs no change.
    One of the spare starters works when connected directly to a battery but when in the engine the solenoid just makes a clicking noise.
    1984 Honda ATC200ES BIG RED x6
    1983 Honda ATC200E BIG RED x3
    1984 Honda ATC70 LITTLE RED
    1983 Honda ATC185S(200E engine)
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    Pull the flywheel cover off. I'd suspect maybe a chipped or broken starter reduction gear. If that is the case, the pieces of metal can get into the stator and ruin the coils
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    6,813
    Also to add to what Dave told you the gears go bad from the one way starter bearing that fails so that should be replaced as well .
    111
    Thank you both will check ASAP
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
