Thread: 1981 ATC185S / ATC70 front brake
    Feb 2017
    Vancouver BC Canada
    9
    Looking for the bolt pattern measurements of a 1981 ATC185S front hub...the model with no front suspension and a three bolt hub. Want to add a drum style front brake to my '84 ATC70.
    Thanks
    Rick
    6,818
    Hub is 3 x 100mm for the early s model .
    It’s the same bolt pattern as the atc70 .
    Last edited by shortline10; 08-26-2020 at 06:13 AM. Reason: Error correction , thanks Hairy , getting old sucks
    Jun 2013
    Oceanside, CA.
    617
    Shortline was close, wheel hub bolt circle is 3 x 100mm. Find this an interesting modification, please post up your completed project. The s hub will need to be modified to keep the wheel centered.
    "HJ" Name:  oldfogey.jpg
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    Feb 2017
    Vancouver BC Canada
    9
    Thanks for your help !
