Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 1983 Honda 200e bogs/dies on full throttle from stop
    Aug 2020
    CA
    8
    I confirmed the main jet is #95 and the pilot jet is #38. The carburetor itself is a PD55A. So far I have rebuilt the original carb and cleaned everything, no change. I've rebuilt the original carb with the shindy carb kit, no change. I even bought a replacement carb from Amazon, no change. I've tried every combination of idle mixture setting, idle speed and needle clip positions with no change except for the needle in position #3 runs the best.
    Maybe up the idle jet size?
    Aug 2020
    CA
    8
    I upped the idle jet to a 42 and the issue is much better. I'm gonna leave it and call it good. Thanks for everyone's help.
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    Is the carb making a good seal to the manifold and manifold to the head? Maybe put a coat of RTV at each to be sure.
    Check the rubber gasket at the slide cap to make sure it makes a good seal also.
