Thread: 1983 250r Honda ATC rear brakes, Help
    Sep 2020
    michigan
    I just picked up a 1983 honda 250r the other day and it needs rear brakes. I need a rear caliper, rear master cylinder, and everything in-between. My question is am i stuck hunting down original parts and piecing it back together or does anyone out there know what i can buy new that will fit for my atc?
    Appreciate Y'all
    - Jarrod
    Connecticut
    1,605
    Be sure if you buy parts that they are correct for 83 or 84 There are differences https://www.partzilla.com/catalog/ho...1983/atc250r-a
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    398
    Caliper is hard to find and expensive when you do find a good one. Let me know how that comes out?
    Jul 2016
    Kentucky
    61
    Arkansas
    2,447
    Unless you want to drop some coin, you should research aftermarket options.
    Used, abused, rebuilt OEM parts are stupid expensive. There's almost certainly some caliper and master cylinder with the same mounting configurations that'll work. The brake hose is probably the same 10mm hose just about every quad, trike, and motorcycle uses, no need to buy OEM for that. Figure out the length and buy one on Amazon or EBay.
    Jul 2016
    Kentucky
    61
    Or, buy the exact one, one time. No guessing or what ifs and it’ll work. Choice is yours.
