Results 1 to 2 of 2
Thread: Atc 70 crankshaft questions
    Jan 2011
    Greene,Ia
    688
    So something happened today, that didn't exactly leave me feeling good. I was attempting to remove the nut that holds the flywheel on. It was super tight, so was using a electric impact to remove said nut. It still came off hard, the started wobbling as it was coming off. Stripped the crank out pretty bad. Ripped threads off crank, and the nut. Haven't seen that happen before. So now I get to remove the crankshaft and put a different one in.
    So here's my question. This is on a 1979 atc 70. Do I need a year specific crankshaft as a replacement? Or is there certain years I can use? Reason I ask is because of the few transmission differences through the years, and I figured you'd need a specific crank for the trans and everything else.
ID:	264213Click image for larger version.
ID:	264212Click image for larger version.
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
    6,810
    1978-80 used the same crankshaft , 81-85 used a different flywheel so their different .
