Thread: 85 Big red air box rubber boot seems petrified ! Wont even bend! Help!
    Jun 2018
    Holland Mi
    93
    Hello I was able to remove the boot between the carb and the air box but its so damn STIFF I cant even get it back on 1 What do I do ?? Use a hair drier ? Put it in the oven ? Torch ??
    Nov 2019
    Florida
    1,053
    Heat it up with a heat gun for about 30 sec. it will slide right on.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Aug 2005
    CT
    208
    I've also used a heat gun with good luck several times.
    Wintergreen oil is supposed to work really good at softening them up but I haven't tried it yet.
    MN
    3,263
    I toss em in a bowl of boiling water, let them soften back up nice, a good 5 minute soak does wonders! Then i wear some gloves cause its gonna be hot and put it back on. Once it cools it will harden back up some, but it will stay a bit more flexible for a while.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
