Results 1 to 15 of 23
Thread: Fuel, spark, compression, timing but won’t start
    Oct 2020
    South Carolina
    13
    85 ATC 200x has proper cam and spark advancer timing, it’s getting fuel, has compression, and has nice blue spark but it still won’t start any ideas? I’ve checked everything with a multimeter and doubled checked everything but it wont fire over at all!
    Cold Lake, Alberta, Canada
    3,019
    Seems like you've tackled most things but could it be 180 degrees off on timing? Or maybe the woodruff key on the flywheel is spun a bit?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Oct 2020
    South Carolina
    13
    I’ll have to check the woodruff key is it left hand thread measuring clockwise to loosen?
    3,019
    Sorry, not familiar with that engine but a manual should clear that up if you have one. I suspect it's a right hand thread as I've had them off on a 70 and a 200 Big Red and that's what I've found.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    6,819
    Std threads , lefty loosely- righty thighty
    Btw their are no reverse threads on the 83-85 200x motors .
    86/87 200x their are though .
    Jul 2016
    Kentucky
    61
    Check valve clearance. Be sure you’re setting everything with piston TDC on the compression stroke. Take the plug out and hold your finger over the hole while you slowly turn it over. When it’s pushing air out of the hole you’re on the compression stroke.
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    Check that your advancer is not 180° out
    That'll cause this issue....
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Oct 2020
    South Carolina
    13
    Valves are good
    Feb 2016
    Stellenbosch, South Africa
    196
    Then it can only be your carb, take your air filter off and try spraying some quick start through the carb body so it reaches the cylinder, if it sounds like it wants to go after a few kicks, then you know all else is good you need to pay attention to your carb.
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1983 Honda ATC200X
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC200ES BIG RED (FatCat Conversion)
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2002 Yamaha Breeze 125 (sold)
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Oct 2020
    South Carolina
    13
    Tried starting it with no carb on and it still won’t start and I tried gas down the cylinder too which would rule out the carb if it ran
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    I still think it’s electrical. I know you checked the on off switch but I would put a meter on it and make sure it’s not shorting out
    Oct 2020
    South Carolina
    13
    Tried it with the kill switch unplugged, also when I kick the motor one time it sparks once and has a blue spark, shouldn’t it spark multiple times for one kick?
    Jun 2014
    utah
    436
    Yes should spark many times per kick
    Oct 2020
    South Carolina
    13
    Yeah what would cause that?, I tried a new spark plug, a Cdi and spark plug coil and wire from a running ATC 200x, pulse generator measures within ohm spec and so does the stator, stator put out 6-12 volts and when ohm testing it goes from 220 down to 216 over 10-20 seconds and then holds at 216
    Jun 2014
    utah
    436
    Did you paint frame? Is the coil making a good ground where it bolts to frame?
