Results 1 to 3 of 3
Thread: New bore, new jets?
    Oct 2020
    Independence, LA
    3
    New bore, new jets?
    I am reviving a 1984 honda atc 200es. The original cylinder bore is 65mm. I decided to get a new cylinder kit, but the bore is 65.5mm, which is the equivalent of having a jug bored out twice. Do I need to rejet my carb? My main jet is #95 and my pilot jet is #38. Thanks in advance.
    6,810
    No re-jetting needed unless your going with a high compression piston .
    If you purchased one of those eBay 65.5 cylinder kits ? Those kits are for a different style motor , some guys say they’ve made them work by blocking off the timing tensioner hole . Just make sure the deck cylinder and piston heights are correct on the new parts .
    Oct 2020
    Independence, LA
    3
    Thanks for that info. I was worried about that, but I figured for $50 it wouldn't hurt to check. Back to the drawing board...
