Atc 200 e recoil kickback
New to me engine, Pull's over ok then when it fires the recoil rips your shoulder out of socket and then quits. Magneto set at T and cam lobes should be down with the pin on the cam shaft that holds the advance ... at 11 o clock position.. cam sprocket O is at top...then turned Mag to the F mark and set cdi straight at 12 o clock position...,,any ideas ?
250r dust runner
