I have an 85 Bigred and the foot brakes are dragging in the one. The first problem is the cotter pin was broken off the pedal allowing the return spring to slide off the bracket it attaches to. I got the cotter pin drilled out and the spring back on but the side that attaches to the bracket is only going on about 1/2 way if I tip the bottom of the spring towards the bike it will go all the way but slides back. I could probably leave it but It would be better if the spring was attached all the way. Can someone send post a picture of how the spring is supposed to be on the pedal. Thanks
