Results 1 to 15 of 18
Thread: anyone have luck mounting used tires?
    az
    2,011
    my next project needs two tires. guys got a pair of old lobbies for 20 bucks, ive busted down old tires and most were rock hard.
    So the question is, anyone have luck mounting older tires or just go pay a few extra bucks and buy new? I think a pair of new 22x11x8 knobbies are 90 bucks delivered vs 20 bucks and never getting it to seat? jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Cold Lake, Alberta, Canada
    3,019
    I'm sure with a little perseverance and some well placed ratchet straps you should get them mounted up in no time. Maybe warm them up a bit first with a heat gun, might make them more pliable. There's always the ether and match trick.....wait, don't do that!
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Nov 2015
    Davenport iowa
    1,144
    One piece rims or split rims?
    1974 original 90 X 2
    1974 Original 70.
    az
    2,011
    split rims.
    81 185s
    82 185s
    and a 72 ct70
    Apr 2014
    Edmond, KS
    2,591
    Before you buy the used ones, if you go that way, look at the bead areas of the tires. I've removed a lot of old tires that had the rubber pull of of the tire in this area. I don't think that they would seal up if there's any rubber missing. Here's my take and experience with old tires. When I bought my 250SX on labor Day weekend, 2014, the rear tires were ok, but the front tire had some weather checking. If I aired it up to 4 PSI, it would be completely flat after 4 days. I didn't think that it was too bad so I bought a bottle of tire sealer, put it in the tire, and never had to air it up again. Fast forward to the following July and I took it out to Colorado t go riding in the mountains. When we were about 10 or 12 miles from camp, the sidewall let go. I had to put my back side as far back as I could to take as much weight as possible off of the front tire, but I did make it back to camp. By the time that I got back, there was sealer all over me and the front of the SX. I didn't look at the tire after it went flat so I don't know how big the hole was at that time, but here's what it looked like after getting the tire off at home. After that, I said that I'd never go riding very far (especially up in the mountains) with tires that are questionable. All of my riders have good tires on them. Just the thought of how miserable it would have been if one of the rear tires had given out has made me not worry about the cost of new tires. I just buy them and put them on.Click image for larger version.
    az
    2,011
    its basically a pair of rollers is what I need. Tires on there are split wide open. I could cut a pair of discs out of 1/4 inch plywood and bolt them onto the hubs to make rollers in back. Jim
    81 185s
    82 185s
    and a 72 ct70
    Arkansas
    2,447
    Dang it...brought me back to my childhood.
    https://www.youtube.com/watch?v=Afofc_Jt86s
    Arkansas
    2,447
    Quote Originally Posted by Jim mac View Post
    Roller or not, you're probably going to take a test ride on it sometime.
    Anything dry rotted or worn out, I toss. No exceptions. I just mounted up some tires today, that I've had for years, onto a riding mower that's been relegated to trailer duty. They were too stiff for any of the trikes, but just fine for a low speed lawn tractor. The reason I've kept them is they had no dry rot, and I've stored them out of the sun and weather since taking them off the parts trike I bought years ago.
    I've met my monthly allotment for tire disposal at the landfill, so I have to wait until next month before hauling my next load of junk tires off, but I certainly keep a stash of useable ones in the tractor shed for rollers or anything else needing a quick pair.
    az
    2,011
    I can fit 1 knobby in the trash can when I have to get rid of the odd tire once in awhile. The tires on my 110 are good but rock hard. Maybe order a full set of three, stick them on the 110 and stick the used set on the project. Jim
    81 185s
    82 185s
    and a 72 ct70
    Arkansas
    2,447
    If you have any used tires with a little bead damage, you could try some bead sealer.
    I've used this a good bit while working in tire shops:
    Xtra Seal Part Number: 14-101B 32 oz. (945ml) Extra Heavy Duty Bead Sealer Flammable
    http://31inc.com/products/32-oz-945m...ler-flammable/
    It comes in three flavors- Bead Sealer (14-101), Heavy Duty (14-101A), and Extra Heavy Duty (14-101B) like the link I listed.
    You'll have to order it, because I doubt you'll find it on any store shelf. All of them are listed for commercial or professional use. I couldn't even find any for sale at big truck shops that carry the Xtra Seal brand.
    az
    2,011
    actually oriely auto parts keeps it in stock, I just bought my second can of it last month. I have a old centerline rim with some pitting on the mounting surface and that stuff sealed it great. jim
    81 185s
    82 185s
    and a 72 ct70
    Nov 2019
    Florida
    1,053
    For me mounting old tires is a crap shoot, I broke down some very hard old tires, but no cracking, I got them off, cleaned and painted the wheels, wire brushed the crude on the beads, now they leak air, I took them back off and replaced with new tires, no more leaks. That's an hour I will not get back.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Oct 2020
    ME
    113
    old tires are no Bueno on anything, just ask Paul walker.
    Even if it wasn't for the extra pain of getting them mounted/dismounted, OR the durability/safety issue like 350for350 brought up.. they simply wouldn't perform as good.
    The only time old, hard tires should be put on a trike IMO would be for a 100% factory museum type show piece that doesnt get ridden.
    1980 Honda 110-125 lifan manual clutch *in progress*
    1985 200x - building peice by piece
    az
    2,011
    I ended up messaging the seller and decided to just buy 3 new tires for the 110. used tires and rims will go on the 185s to rollers. jim
    81 185s
    82 185s
    and a 72 ct70
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    Lol, I remember those! I think my cousin had one . . .
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
