Page 1 of 8 1 2 3 ... LastLast
Results 1 to 15 of 115
Thread: Perplexed-Need Help X 4
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    398
    About 3 months ago a guy outside of Butcher Hollar, TN sold an enclosed box trailer. The guy who bought it decided to sell the four three wheelers that were in it and I decided to buy them. The guy said that the original owner was from California and bought the trikes from there and they hadn't been out of the trailer since and that was over 20 years ago. The newest Cali registration sticker is dated 1995.
    The bikes look like new to me. The tanks are clean. The plastics are good for the most part and most of the cables even still work! Minimal surface rust at the most. Seat pan are even pretty good on one of the 81 200s (No letter). Although there are twelve flat tires and evidence of a varmint bedding in a few of them.
    2 81 200 (no letter) and 2 85 250SXs.
    I decided that I would start working on one of the 200's (no letter) over Christmas break. The pull cord was out so I took it off and began to get it freed up and in working order which I did.
    I was about to order tires for the 200 (no letter) when I decided to check and see if the engine would turn over with my ratchet. It wouldn't...hmmm. I pulled the plug and poured some marvel mystery oil down the hole. I went back today and it still wouldn't turn so I checked the other 200 (no letter) and it was the same way. Locked up.
    Then, I checked the two 85 model SX's and when I put pressure on the kickers-they weren't budging either. ???
    What would cause all four engines to seize up? They look very good and clean. The oil looks clean.
    Thoughts? Suggestions?
    They are all soaking in Marvel Mystery oil right now. Possible tips? Possibly what happened?
    Thanks in advance.
    6,798
    Make sure their weren’t any mouse nest in the air boxes ?
    Mouse piss is like liquid acid and will seize a piston .
    Mar 2020
    Palestine, AR
    398
    There was mice all in them. Should the marvel mystery oil get them unstuck? Thanks
    Mar 2020
    Palestine, AR
    398
    Barnboy: I totally agree about pics!! For some reason, I can't post them anymore since my computer updated.
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    This thread is worthless without Let's see em Patriot!
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Jun 2015
    Oklahoma
    732
    Quote Originally Posted by patriot1 View Post
    Its probably easier to do it off your phone...it is for me anyway. Unless you don't have a smart phone. Saves the extra steps.
    Da velder
    Feedback:
    az
    2,001
    I've used mmo and trans fluid to free up stuck motors. matter of fact, my latest pos project sat at this guys yard for almost 20 years. I bought it for the forks and spark advance but he gave me the rest of the trike for 10 bucks including a motor sitting without a plug outdoors. ive filled the cylinder with trans fluid for the last week, it just broke free. So let it sit for a week, take off the pull start and use a breaker bar and socket and try to turn it over. my last 185s project was also stuck, couple days of soak and it freed up, runs great too. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Mar 2020
    Palestine, AR
    398
ID:	265633Click image for larger version.
ID:	265634Click image for larger version.
ID:	265635see what this does from my razor flip phone
    Mar 2020
    Palestine, AR
    398
ID:	265636Click image for larger version.
    Mar 2020
    Palestine, AR
    398
    Can't tell much about the problem from those pics but I got em. Thanks Jim!!
    Mar 2020
    Palestine, AR
    398
ID:	265638Click image for larger version.
    Jun 2015
    Oklahoma
    732
    Looks good Patriot. Possible that the trailer leaked, moisture settled in there over the years. Best stuff for freeing stuck objects is Hagens brew. It's a 50/50 mix of acetone and diesel fuel, ATF, etc any thing oil. Shake it up a bit and let er soak, works wonders.
    Da velder
    Feedback:
    Mar 2020
    Palestine, AR
    398
    I'm leaning toward rat piss. Rats had nested everywhere they could. Big nest. A lot of nest. I'm going to let it sit for a week like Jim suggested. I'll try to get pics of the other ones also.
    Jim: How much torque did you put on your breaker bar? I've been worried about pushing too hard and breaking something.
    Nov 2015
    Davenport iowa
    1,144
    No kidding? I didn’t know that Shortline
    1974 original 90 X 2
    1974 Original 70.
    az
    2,001
    not too much torque, just push one way then the other. im using a real 1/2 breaker bar. jim
    81 185s
    82 185s
    and a 72 ct70
