Thread: timing position?
    az
    2,001
    timing position?
    I know you need a timing light to be accurate, but generally when setting the timing where do most of you find the plate ends up? last motor i popped the cdi cover and noticed the slot was all the way retarded (slot to the notch) I moved the plate where the notch in the plate lined up to the slot in the middle and the motor wanted to fire up. Im going to move it to the advanced edge of the notch to the slot. (notch is about 2 o clock) jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    MN
    3,263
    No timing light needed, they all have timing marks. If it won't run with the factory ignition timing then i would check the cam timing to make sure its not out, skipped cam chain, someone put it together wrong, etc. For example on a 200 series motor you set the crank to the T mark for TDC, then check the cam gear timing to make sure its dot is lined up with the notch/line on the rocker cover, then to set ignition timing you set the crank to the F mark for Fire, then you just adjust the pulse gen to match the line on the advancer at whatever position it ends up. That generally puts you around the middle of travel on the pulse gen mounting plate slots. If it won't run in that position then something is wrong. From there you could advance or retard it a bit, but i have never had to do that to make them run right, just setting the factory timing does the job.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    az
    2,001
    thanks. should have posted, went and looked at it that night, timing was way off. lined up the F and advancer to the cdi trigger and it fired up. jim
    81 185s
    82 185s
    and a 72 ct70
    MN
    3,263
    Sweet... That's always a good feeling.
