Thread: Swing arm bearings or bushings?
    1985 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    Olean, NY
    335
    I have a YTM225DX that needs swing arm bearings. I am under the assumption, from parts in catalogs, that these can be replaced with a bushing and that will give a longer wearing connection. True or False? Anyone have input on this? Thanks Rod
    Nov 2002
    1,189
    I'm not sure, but I've never replaced the bearings in mine. As long as their clean, and have good seals, and are greased, they should last forever. The only bushing that I'd go with would be an oil-lite or a nylon one. Not sure if you want high silicon or not. I'd think you'd want low. Metal bushings wouldn't be worth it.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Aug 2003
    Olean, NY
    335
    Mine are shot to the point that when I lift up and down on the grab bar there is noise and movement.
    I went throught this last weekend (200x). I replaced bearings, bushings, sleeve, bolt, and dust seals. I had the same prob. The bearings were gone.
