Results 1 to 3 of 3
Thread: 1984 200X help
    Jan 2021
    Conroe, Texas
    1984 200X help
    Before I start twisting and beating on things I am not familiar with, how do I correctly remove my front axle from the hub? I am trying to replace the bearings.
    Apr 2014
    Edmond, KS
    2,591
    If the front tire/rim/hub combo is off of your trike, then the axle should just slide out. I did say "should" because a lot of times there is some rust inside the hub and then the axle removal "fun" starts.
    Jan 2021
    Conroe, Texas
    Thank you, Ill try tapping with a dead blow tomorrow.
