Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Thread: im getting to old to kick start the 350x
  1. #31
    Nov 2019
    Florida
    1,048
    Bob Marlin, I have my sequence, mind sharing yours?
    Also anyone running a 400ex carb on there 350x?
    Thanks
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
  2. #32
    devore,ca
    1,056
    There is 3 things that make the 350x hard starting.
    1) Not understanding there IS a right way to start them
    2) Dirty carb
    3) Misunderstanding of how the decomp system works on these particular engines
    For the sequence- choke on if its a cold start. SLOWLY move the kicker trough 2 cycles. Move slowly into a third cycle taking notice of when it is on the compression stroke and builds compression, As soon as you feel it go just passed the compression stroke-just barely passed-let the kicker return back up- then give it a good kick. Should take no more than 2 or 3 kicks repeating the sequence every time. This way you are not kicking at full compression and it won't kick you back.
    A dirty carb will cause way more starting problems then one that is just out of adjustment.
    The decomp is not an automatic one , but rather than having a lever on the handlebars its connected through a cable to the kick starter shaft. It has NOTHING to do with making it kick easier . It is there only to make it easier to slowly get the piston to the right place BEFORE you kick it. It really isn't needed unless you have a GOKI, then it's a must. I've seen more problems caused by a "functioning" decomp then a broken one. If it is a working decomp that is out of adjustment it will hold the exhaust valve open and make it hard to start.
    I have a friend that's running the ex carb. It's a tight fit. The performance increase is minimal if any over a GOOD 350x carb. But if you have an old worn out carb now it will seem like a big improvement.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
  3. #33
    Feb 2017
    Arkansas
    531
    Quote Originally Posted by BOB MARLIN View Post
    2) Dirty carb
    Haven't had the opportunity to kick mine off in years since I tore it apart but ^that sequence^ worked as smooth as buttah (butter.)
    Didn't even realize that was what I was doing but after kicking it several hundred times, that sequence became automatic and you could 'feel' it in the kickstarter. Not sure how else to describe it (see Bob above) but they start easy if the carb is clean and you get that sequence down.
    Cold starts weren't even a problem. Full choke and no throttle.
  4. #34
    Nov 2019
    Florida
    1,048
    2) Dirty carb
    And that is how you make a sticky. Thank you for taking the time to write it out in plain english. I have not been short stroking it as you suggested. Thank you.
    MrC.
    My Addiction
    86 350x
    84 250r "lucky"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
  5. #35
    Arkansas
    2,447
    Ultimately, it's an anti-theft device.
    Just don't park at the top of a hill.
  6. #36
    Jul 2008
    south jersey
    20
    thanks to bob im up and running
    84 big red
    85 250R
    85 200x
    85 350x
    05 450R
  7. #37
    Feb 2021
    Burgh
    12
    What is necessary to talk you outta your Goki? Thanks, Andy
  8. #38
    devore,ca
    1,056
    Quote Originally Posted by XRyder View Post
    I just sent you a PM.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
  9. #39
    Jul 2008
    south jersey
    20
    heres what all the fuss was about
    Attached Thumbnails Attached Thumbnails 84F1341A-1CD1-47A6-8C27-7360B0E8E131.jpg   529B3DF8-8730-4AFF-A831-595784DE139D.jpeg
    84 big red
    85 250R
    85 200x
    85 350x
    05 450R
  10. #40
    Jul 2008
    south jersey
    20
    no electric start here
    Attached Thumbnails Attached Thumbnails 7D6820EB-FDB0-40EF-A4C7-8D12C6A2AC08.jpg
    84 big red
    85 250R
    85 200x
    85 350x
    05 450R
  11. #41
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    Quote Originally Posted by WIGGLES View Post
    That's a set I love to have some day. I've got two of the three, just don't know if I could justify spending the $$ on the 350x because I'd just be grabbing it to complete the set, lol. The 200x is for riding alongside my daughter while still being able to have fun, and the 250r is for grown-up only riding, haha. The 350x is similar enough to the 250r in regards to the riding that I do that it would basically be a duplicate . . .
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
  12. #42
    Nov 2019
    Florida
    1,048
    Man, I'd through that Grand National away if it didn't have electric start.
    Very nice set
    MrC.
    My Addiction
    86 350x
    84 250r "lucky"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
  13. #43
    az
    2,045
    I did like you guys posted to start my 350x on Saturday and it worked like a charm. I was washing the machine and only had my flip flops in and still started with ease. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
  14. #44
    Jul 2008
    south jersey
    20
    Quote Originally Posted by MrConcdid View Post
    Very nice set
    MrC.
    yea im kinda stuck in the 80's
    84 big red
    85 250R
    85 200x
    85 350x
    05 450R
