Results 16 to 30 of 73
Thread: 2000 yz250 trike conversion
    Mexico
    9,018
    Quote Originally Posted by plevib View Post
    I was originally thinking I would start from scratch, but I think I've decided to use a banshee swingarm.
    FYI, I used an aftermarket Banshee hub for my swing-arm and discovered it was offset 1” to the left way too late to change my mind. I assume the issue is that the Banshee engine started life out as an RD 350 in a street bike chassis, so the output shaft is further to the left than a single cylinder dirt bike would be. Fortunately I’m running a Tusk axle that comes with an assortment of spacers, so I was able to get the axle centered to the front wheel. I’m sure you can make it work, just be aware that you might have to work around some amount of offset if you use a Banshee set-up.
    In the end I had to run the sprocket on the inside of the carrier and also had to get some material machined off it in order to align the sprockets. If I want to change the sproket I have to remove the sprocket carrier from the axle.
    It sucks to get old
    devore,ca
    1,054
    You end up with a similar offset problem using the so called "bolt on YFZ swingarm". Even though Yamaha YFZ quad and the YZ450f and the WR450f all have "Basically" the same engine., The quad tranny is wider than the ones in the bikes so the sprockets don't line up. I had to move the rear sprocket to the inside plus add a spacer. The problem that pops up when doing this is there is only so much you can move the sprocket over until you hit the swing arm. Mine was a custom swingarm so I could design around it, but if you are using a existing swinger take measurements to make sure you have the room to move it over to get everything lined up.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Oct 2011
    Glamy's place
    98
    I think you should stick with the bike linkage setup. It would be easy to limit travel with the bumpstop and probably a much better design. Not that you can't get banshees setup well, but they are not known for great suspension. Your bike shock will have high and low speed compression adjustments and the banshee only has a general compression setting. I think you should also reconsider the low seat height. In my experience, the seat height difference between a 350x or even a 250r and a tecate makes a huge difference in rider fatigue. That depends on how long your legs are though. Riding my tecate reminds me a bit of a bike in terms of ergonomics and I think it is the way to go. I can ride harder for longer because I am not doing an ATG squat everytime I sit down.
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    I did forget that the sprocket was so far out on banshees...... hmmm...... I'll keep thinking about my options. I did have to space out my yfz rear sprocket on the xt550, about 1/4 inch.
    Quote Originally Posted by legacy51 View Post
    I think you should stick with the bike linkage setup....... I think you should also reconsider the low seat height. In my experience, the seat height difference between a 350x or even a 250r and a tecate makes a huge difference in rider fatigue. That depends on how long your legs are though.
    The last conversion I did I kept the bike shock and it was too tall. Hanging off the seat in aggressive turns was more tiring to me. It's more comfortable to ride my 200x and im 6'4". I want a low seat height, I won't be jumping 15 feet in the air
    Atc 500x for the win! (Hopefully.... one day)
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    I’m working with sprocket offset on my build so I figured I’d throw in here what I did to solve mine on a 185s axle. I think it came out nice. Just something to give you brainstorm ideas
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Hey does anyone know what the fork length on a 85-6 250r is from axle to top of tube? I have a chance at some that might work for me.
    Las Vegas, NV.
    2,531
    Going solely off of my bad memory, 39” sounds very familiar.
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    I hope to get some time in the garage tomorrow, I'll try to remember to get a measurement.
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Anyone get a chance to measure? 39 sounds really long to me, that's what the yz250 forks are stock
    Las Vegas, NV.
    2,531
    Yes, I agree. I was out in the garage the other day and roughly put a tape measure to my inverted setup, and it was no where near 39". Granted, it was sitting on the ground with a bit of sag, but not that much sag. I must have been remembering the length of full-size dirt-bike forks. If you like, I will measure my setup with no sag. I know the length of the KTM 85SX forks, that I used, was pretty close (probably within 1/2" or less) to the OEM 250R forks length.
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    That would be awesome if you get a chance to do that! Thanks!
    Las Vegas, NV.
    2,531
    Measuring my inverted forks, with front end off the ground & no sag, they are 32 7/8" from the top of the fork cap to axle center.
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    So here's some 2002 yz85 forks. Measure 33 inches axle to top, so very very close to stock 250r. 10ish inches of travel so the frame won't hit the ground. and I can get heavy springs for them.
    I got a chance to measure a 250r this weekend and I don't need to do as much modification as I originally thought to get close with this frame. Changing the head tube angle is the main work. The distance from the swingarm bolt to the head tube is within a half inch, and the position of the swingarm bolt relative to the whole frame. I will end moving the rear shock mount to match the banshee shock.
    But as usual when I have time for these projects I'm broke, so I'll keep up the snail pace
    I have a 1x6 inch chunk of aluminum in the mail along with stuff for the front axle. I'll just have to show you my plan up front.
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Soda blasting parts while I wait for my aluminum for the triples
  15. #30
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    https://youtu.be/xnWqY7AllWE
    Got the front axle done, next up is the clamps
