Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 73
Thread: 2000 yz250 trike conversion
  1. #31
    Couldn’t you just change the rake buy just rotating the frame and lowering the subframe
  2. #32
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    I suppose a person could, but you'll dip the frame closer to the ground, tilt your foot pegs down, and possibly some other issues I can't think of. Anyways triples are built with 6 degrees so it's too late now, but I think the bike will handle best like this anyways.
    I'm REALLY happy with how these turned out. I don't have a mill so these were built with a chop saw and a cheap drill press. 6 degrees of rake built into them just like a 86r. I really couldn't be happier with the results. I'll post a video detailing the whole process. I think this could be a great option for the guys who can't afford CNC'd triples.
    Atc 500x for the win! (Hopefully.... one day)
  3. #33
    There was a guy on here that used a router to radius a aluminum rotor adapter the a conversion he did. It turned out pretty good too
  4. #34
    devore,ca
    1,054
    "I suppose a person could, but you'll dip the frame closer to the ground"
    The frame actually gets farther away from the ground because your axis of rotation becomes the front axle. But you're way past that now.
    One of the best changes I did on my conversion is bigger foot pegs. If you get a set for a YFZ quad, you can trim the mount end a bit and they slide right over the YZ bike peg the weld them together. That way you keep the stock mount and the spring loaded fold back feature.
    What was the angle of the resulting rake you were looking for ?. Measured at the fork leg with an "angle finder" I was able to get 24 degrees, which is right on with what my 350x is.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
  5. #35
    Arkansas
    2,447
    I have a question on the fabrication of aluminum parts.
    Exactly what needs annealed to work/machine, and what needs heat treating before putting into use?
    I know many materials require certain treatments after final fabrication, to reach their full strength and fatigue resistance.
  6. #36
    devore,ca
    1,054
    I know much more about steel than aluminum, but my understanding is Aluminum is purchased in its heat treated/annealed state. Steel goes through a heat treat after machining or at least before finish machining. Wear items such as gears get heat treated for surface toughness other things get heat treated differently for impact resistance( like a ) or twisting (like a truck axle). I can't think of much on a trike that needs any heat treatment outside of internal engine components and rear axle.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
  7. #37
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    https://youtu.be/6hv_IFYfl6g
    Here's the build video for the triple clamps. I'm very happy with the end result for the 75 bucks worth of aluminum. Next up, taking 6 degrees out of the frame!
  8. #38
    Oct 2011
    Glamy's place
    98
    Nice looking triples and thanks for the video! That should make it more doable for others to copy.
    Do you know how much trail a 250r has? I am curious what it comes to. A first gen tecate has about 1.6 in which is a lot less than dirt bikes. Most dirt bikes seem to have 4-5 in of trail.
  9. #39
    Oct 2011
    Glamy's place
    98
    I think I found the answer to my own question thanks to barnett468.
    1984 ATC250R
    rake ............................ 69 mm . This is measured from horizontal instead of vertical so using current methods, the rake is actually 31 degrees but it is unknown if this is the forks or the steering head.
    rake forks ....................... ?
    trail ............................. 45 mm . . 1.8 in
    w.b .......................... 1197 mm . 47.1 in
    dry weight ......... ..... 302 lbs
    dry bias ..................... ft 117 . rr 185 lbs
    bias percentage ........ ft 38.7 . rr 61.3
    axle position ............. trailing
    tripple trees .............. unknown but look staggered which would make sense
    1985 ATC250R
    rake .............................. 21 deg
    rake forks ........................ ?
    trail ............................... 37 mm . . 1.45 in
    w/b ........................... 1295 mm . 51.00 in
    dry weight .................. 291 lbs
    dry bias ...................... ft 117 . rr 174 lbs
    bias percentage ......... ft 51.3 . rr 48.7
    axle position .............. trailing
    triple trees ................. unknown but im guessing they are staggered the same as the 86'
    1986 ATC250R
    rake forks ..................... 30 deg ? . . if this is the fork rake then these tripple trees are staggered 9 mm
    trail ............................... 38 mm . 1.5 in
    w/b ........................... 1905 mm . 75 in
    dry weight .................. 289 lbs
    dry bias .................... ft 116 . rr 173
    bias percentage ......... ft 50.9 . rr 49.1
    axle position ............... leading
    tripple trees ................ staggered 9 mm?
    1984 and 1985 TECATE
    rake ............................. 24 deg
    trail .............................. 40 mm . 1.57 in
    w/b .......................... 1280 . 50.4 in
    dry weight .................. 286.6 lbs
    wet weight ................. 312
    wet bias ..................... ft130 . rr 181
    bias percentage ....... . ft 42 . rr 58
    tripple trees ................ non staggered
    1986 TECATE
    trail .............................. 48 mm . 1.57 in
    w/b .......................... 1280 mm . 50.4 in
    dry weight ................. 280 lbs
    wet weight ................ 299 lbs
    wet bias .................... 121 . 178 lbs
    bias percentage ........ ft 40.5 . rr 59.5
    axle position .............. leading
    tripple trees ............... non staggered
  10. #40
    devore,ca
    1,054
    If the above is true, does that mean that the 86 R has 9 deg. built into the clamps and not the 6 that we have all been told ?.
    Also I doubt very much that the 86R is 2 feet longer than the 85R, I'm assuming w/b means "wheel base" ?.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
  11. #41
    Mexico
    9,018
    Quote Originally Posted by BOB MARLIN View Post
    Rule #1 of TWW: If Barnett468 posted it, it's a FACT
    Rule #2 of TWW: If you think Barnett468 is wrong, see rule #1
    It sucks to get old
  12. #42
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    It also says that the 86 is a leading front axle, I've only got first-hand experience with my 85 but every pic of the 86's I've found is a trailing just like mine . . . ?
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
  13. #43
    Mexico
    9,018
    Quote Originally Posted by jasong_10 View Post
    Obviously someone is turning these axles around and putting pictures on the Internet to try and undermine Barnett’s FACTS. Don’t be fooled by these obvious forgeries!
    It sucks to get old
  14. #44
    devore,ca
    1,054
    I didn't notice the "leading axle" part. That's definatly wrong. I'm not so sure about the trailing numbers either.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
  15. #45
    Oct 2011
    Glamy's place
    98
    Minor details! Who knew that the 84 250r had 69mm of rake too
    In all honesty, the trail numbers all seem believable. I know that the tecate #s are right and that's all that matters!
