Looking to get the suspension set up on the YZ450F conversion trike I bought. I know sag is important on a dirt bike but from what I've read about ATV's it seems the preload is adjusted more importantly to set the ride height. Any suggestions on a good baseline set up for a 3 wheeler? It seems my sag is waaay to much (like over 5"." I measured from the grab bar to the ground and from most advice I've read 30% of the suspension travel is the goal. I'm guessing I have about 10" overall but not really sure. Also wouldn't where you measure the sag make a difference? The farther back you measure the greater the distance as its further from the pivot point? I'm 170 lbs and not sure if the shock/spring is from the dirtbike or the quad but it is stock. I haven't measured the ride height yet which I've read should be about 8" on a quad. Figure I'd try and get some advice before monkeying around with it too much. Anyone with a conversion have input? Maybe Bob Marlin? Thanks Guys! Oh and I like to do MX style riding. Thanks again!
